motul every 5km |
smart man |
If you look at the S2000, Honda is all over the map with respect to the maintenance schedule. Owner's manual says for normal conditions, change it every 12,000km or 12 months. For severe conditions, owner's manual says change it every 6,000km or six months. But if you go to honda.ca and choose S2000, it says change it every 6,000km or three months (both normal and severe). For me I just change it every six months. Truth is I never end up reaching the max kms before the max time. Regular oil is fine for me (never bought synthetic oil for any of my cars, and probably never will unless its required). |
Yes you can do an oil change for $40 and check it for visible substances, or you can siphon off 250 ml and send it for oil analysis for $30 and get a printout of non-visible substances too. The oil analysis report is very valuable, knowing that elevated levels of certain metals/chemicals/moisture/... can identify engine problems earlier than your simple visible check. Please do not call Liquid Turbo a troll. He's provided techniques used by commercial vehicles, racing teams, ... that is available to the public for less than the price of an oil change. Meanwhile you're sticking to outdated garage mechanic tips that waste $$$ and give people false sense of security. |
Vancouver's weather is very unlike most the rest of Canada. |
just use any oil that's manufacturer's spec and has a SM rating. then run to the oil change intervals in the manual. doing an used oil analysis will provided the best way to tell if you should run shorter or longer OCI. though i like using a 0w oil for better pour point at cold starts. even though the manufacturer recommends a 5w-30. better fuel economy, less engine wear, less strain on alternator and battery. for a filter, just use OEM, purolator pureone, bosch premium, napa gold, wix. i would avoid using fram http://www.knizefamily.net/minimopar...reference.html |
My dad's old 83 Honda Civic had over 400,000km using nothing but the dreaded Orange Frams + Castrol GTX conventional (because it was the cheapest) for its entire life until it was sold to the guy in the neighbourhood. I still see him zipping around in it occasionally. That being said, I think there are better alternatives. What engine do you have? What 0w30 you use? M1 AFE? |
Therefore it's consistent with honda.ca's recommendations. |
Read my post again. Owner's manual says for normal conditions, change it every 12,000km or 12 months. For severe conditions, owner's manual says change it every 6,000km or six months. But if you go to honda.ca and choose S2000, it says change it every 6,000km or three months (both normal and severe). |
Honda is saying "there are no Normal conditions in Canada". :thumbsup: Hence the website defaulting to 6,000km for all S2Ks in Canada. But yes, why are we arguing semantics? We agree that 6 month 6,000km OCI is good. Don't the newer S2Ks have oil minders? When do they go off? |
For severe conditions, owner's manual says change it every 6,000km or six months. But if you go to honda.ca and choose S2000, it says change it every 6,000km or three months (both normal and severe). 06 and up had the "Maintenance Minder". Mine is an 05, so I'm not sure. Regardless, I've been sticking with changing oil every six months. I'm only driving around 10,000 kms per year. I'm not worried. |
^ Ahhhh gotcha. I didn't see the 3 month 6 month ! My bad!:D 6 month 6,000km works just fine, especially if you take it to the highway occasionally. Unlike Engine temp, Oil takes 15km-20km to fully warm up and burn off any fuel dilution. 3 month OCI doesn't make much sense either, since a lot of people store their S2000s in the winter. |
Doctors don't test whether you have AIDS or HIV by looking at you. They run blood tests, hence the reason why LiquidTurbo suggested getting your used oil tested & analyzed so you can get reliable data as well as a comparison of what the ppm levels should be at from past data. How would u assess whether there was antifreeze or too much fuel in the oil by looking at the filter material? :confused: And whether or not those levels are acceptable or not for an engine with XXXXX amount of km? |
Funny you mention this. When I leased my BMW E92 I was told not to worry about changing the oil until I hit 15,000 - 20,000 and only do it when the on board computer tells me to. When I got my Audi A5, the first oil change is suppose to happen at 6,000. I even asked my friend at BMW if it's a smart idea to not change the oil say at 5,000. He told me not to waste my money because it was a leased car and let BMW worry about it. He also said some people don't get the oil changed until they hit 20,000 km's. |
i remember being told for the average driver, you can change your oil every 10,000-14,000kms, and that synthetic isnt necessary for these numbers either. ive read all the posts thus far, and im concluding that this is probably fairly accurate? how about the synthetic vs non? |
If you were owning a BMW, that's an entirely different beast. The folks at Blackstone tend to recommend not to ride out BMW's recommendations fully based on the UOA's that they've seen. They only way is to do one then judge the interval that works best. I wonder why BMW stretched to such lengths. Is it perhaps to upkeep a perception of "luxury, less maintenance", or reduce maintenance costs for themselves, (since BMW offers the free scheduled maintenance program)? PS: If anyone wants to look up a database of UOAs, head on over to www.bobistheoilguy.com. This dude didn't change oil on his 3 series for 100,000km. :facepalm: http://img4.imageshack.us/img4/2382/dsc00851m.jpg http://www.tomsandersonphotography.c...S/_MG_2318.jpg http://www.tomsandersonphotography.c...S/_MG_2317.jpg http://img7.imageshack.us/img7/1261/dsc00860rvk.jpg http://img10.imageshack.us/img10/9883/dsc00858w.jpg http://www.tomsandersonphotography.c...S/_MG_2319.jpg http://img194.imageshack.us/img194/2046/dsc00861x.jpg http://www.tomsandersonphotography.c...S/_MG_2321.jpg http://img188.imageshack.us/img188/86/dsc00862twg.jpg http://www.tomsandersonphotography.c...S/_MG_2324.jpg |
:haha: |
man that 3 series is really fucked, needs a rebuild or sth...jesus its like someone shoved mud into his engine |
