Vancouver Auto Chat 2016 VAC Community Head Moderator: Raid3n |  | |
08-14-2010, 02:39 AM
#176 | OMGWTFBBQ is a common word I say everyday
Failed 53 Times in 33 Posts
Originally Posted by LiquidTurbo My opinion is that 5w20 is a 'good enough' lubrication solution, but not the best option. Car makers push for 5w20 as much as they can to reduce their CAFE fees.
I don't think it's right to classify the entire range of 5w20 as 'not that great'.
That being said, I'd happily use quality synthetic 5w20 over a low quality dino 5w30 made from a shitty basestock, assuming that 5w20 is spec'd for the application. But head to head same quality synthetic 5w20 vs 5w30, I'd take the minisicule, immeasurable drop in fuel econ for slightly better wear protection by using the 5w30. | yea i dont like 5w20 very much. but unless it's driven hard, burns excessively or something like that i'd just keep it in DD cars.
half the cars in my house use 5w20
__________________ 1996 Honda Accord 1995 Nissan 240sx 2004 Infiniti G35 2005 Honda Jazz BuySell Feedback Quote:
08-16-2010, 09:45 AM
#177 | I don't get it
a question for all of you, this is the first time i will be changing my own oil at home, and my driveway is slanted, do you think it would be dangerous if I jack my car up on the driveway and use jack stands or would I break any bylaws by doing my oil change on the street?
08-16-2010, 09:57 AM
#178 | Pull Out Towing. Women rescued for free.
Failed 128 Times in 71 Posts
Don't know about bylaws, but type of jack do you plan on using? Jack stands is a really good idea, but what type of pavement do you have? Since it is so hot out, asphalt will go soft and the jack stands might/will sink into the ground.
__________________ Originally posted by Iceman_19 you should have tried to touch his penis. that really throws them off. Originally posted by The7even SumAznGuy > Billboa Originally posted by 1990TSI SumAznGuy> Internet > tinytrix Quote:
Originally Posted by tofu1413 and icing on the cake, lady driving a newer chrysler 200 infront of me... jumped out of her car, dropped her pants, did an immediate squat and did probably the longest public relief ever...... steam and all. | (11-0-0) Buy/Sell rating Christine Shitvic Pull Out Towing |
08-16-2010, 10:13 AM
#179 | I don't get it
its concrete i believe doesnt go soft in this heat we've been having, i think they call it a trolley jack the one I would be using. I'm just worried about the car rolling while I'm working on it.
07-26-2011, 11:35 PM
#180 | Unofficial Tin Foil Hat Specialist.
Failed 326 Times in 125 Posts
Bumpity bump! shameless bump.
07-27-2011, 09:05 AM
#181 | Even when im right, revscene.net is still right!
Failed 1,002 Times in 133 Posts
LiquidTurbo. Thanks man! I've learned a lot from you! =) Now I drive a 03 Sienna 89,000km on the clock, oil change every 5000km w/ mobil 1 synthetic. I do the same with my bro's 06 TSX with 74,000km. I understand that having an oil change every 8k is fine on newer vehicles but what about high mileage? i'm talking about the ones with 250.XXX on the clock?? is it okay to do an oil change every 8000k?
07-27-2011, 12:43 PM
#182 | I Will not Admit my Addiction to RS
As long as you are using the proper, recommended oil (that is of high grade) there is not problem sticking with a 8000K oil change interval, unless your manufacturer calls for something else. That's what my car is on, using 0W-40 Mobil 1, and even after a slew of track days, my oil analysis was spot on. I highly recommend doing at least one oil analysis to see if you can detect excess bearing wear or additives breaking down early.
"Happiness lies in the joy of achievement and the thrill of creative effort"
07-27-2011, 07:44 PM
#183 | I answer every Emotion with an emoticon
Failed 159 Times in 63 Posts
I have been changing mine (M1 0W40) every 12-13k km and it's running fine. Opened up the valve cover to change the seals and no sludge at all
Ignorance is bliss
07-27-2011, 09:53 PM
#184 | I subscribe to Revscene
Failed 37 Times in 17 Posts
I've been following the recommended 6000km interval using Mobil1 5W-30 for my previous car and Royal Purple XPR 5W-30 for the current car. To be honest, just make sure you change your oil at the correct specified interval and you'll be fine. Mobil1 works just fine.
07-27-2011, 10:11 PM
#185 | "Entertainment" mod.
Failed 161 Times in 60 Posts
Oil filters...I just changed oil on my car and since I just bought it, I found out the PO goes to Jiffy Lube since 1. he mentioned it, and 2. there was a Pennzoil oil filter. Since I work at a dealership, I went with OEM (Toyota/Denso). Would I be correct in my assumption that most quick lube shops use Fram-quality filters, and if so, are they poorer in comparison to OEM?
Keep in mind I have read a couple of articles reviewing oil filters, and they say Napa Gold is pretty good. It's the Fram ones that bug me a bit.
Green OJ Special
07-27-2011, 10:22 PM
#186 | RS Veteran
Failed 468 Times in 304 Posts
Originally Posted by CorneringArtist Oil filters...I just changed oil on my car and since I just bought it, I found out the PO goes to Jiffy Lube since 1. he mentioned it, and 2. there was a Pennzoil oil filter. Since I work at a dealership, I went with OEM (Toyota/Denso). Would I be correct in my assumption that most quick lube shops use Fram-quality filters, and if so, are they poorer in comparison to OEM?
Keep in mind I have read a couple of articles reviewing oil filters, and they say Napa Gold is pretty good. It's the Fram ones that bug me a bit. | FYI, word on the street is that Toyota's filters aren't as good as they used to be since Nippon Denso split up. I don't know this for a fact simply because I haven't driven my MR2 in ages.
Napa Gold, K&N, Wix & Purolator filters are supposedly very good.
__________________ Quote:
Originally Posted by BIC_BAWS I literally do not plan on buying another vehicle in my lifetime, assuming it doesn't get written off. | Quote:
Originally Posted by Badhobz I think she’s one of those weirdos who gets off on feeding fat fucks. Pretty sure she feeds me and then goes home to cook her own baooo yuuu with supreme sauce | |
07-27-2011, 11:24 PM
#187 | RS.net, helping ugly ppl have sex since 2001
Failed 236 Times in 60 Posts
Been using Napa Gold since ownership, no complaints here.
Originally Posted by The_AK Or you meet some girl at the club, cum inside of her, find out shes only in grade 12, so you buy a Prada bag for her to make things right, she finds out the bag is a fake and decides to have the kid | Quote:
Originally Posted by RX_Renesis wtf did she get some bolt-on titties or what?
they look sooooooooooo much bigger than they were 2ish years ago. | Quote:
Originally Posted by nns I can't stand the sound of Mandarin either. Boo yow nee bey nee shing bo now noong gey shee mayo mayo mayo mayo mayo mayo mayo. | |
07-27-2011, 11:41 PM
#188 | Even when im right, revscene.net is still right!
Is it worth getting an OEM oil filter? vs Fram.
07-28-2011, 12:14 AM
#189 | Unofficial Tin Foil Hat Specialist.
Keep in mind I have read a couple of articles reviewing oil filters, and they say Napa Gold is pretty good. It's the Fram ones that bug me a bit. | Pennzoil/Quaker State filters are now produced by Purolator. So it's safe to say it's a better overall filter compared to the older findings which were made by FRAM. Though running FRAM(extraguard, High mileage) for 5,000KM OCI should be fine but I'd stay away from all FRAMs other than their Extended Guard/Synthetic Filter. You'd be surprised to find that this particular filter is actually quite well built, 2 layer filter media, Metal end caps, ADBV.
If I remember correctly, some Honda filters are made by FRAM, but the delearship does sell two types apparently.
Don't forget, just because a filter is made with Metal end caps doesn't necessarily mean it's great. The number of pleats, flow, filter material, and the actual thickness of the filter housing plays a big role as well.
07-28-2011, 12:28 AM
#190 | RS.net, helping ugly ppl have sex since 2001
Failed 229 Times in 105 Posts
Friends don't let friends use FRAM
__________________ ⇐ If I bothered replying, that's the face I made while I typed. - 2017 Alfa Romeo Giula Q4
- 1999 Nissan Stagea 260RS 1 of 748
- 1998 Nissan Laurel Medallion Club S drift boi
- 1991 Lexus LS400 mint boi
- 1989 Nissan S-Cargo cute boi
07-28-2011, 08:38 AM
#191 | "Entertainment" mod.
Originally Posted by skyxx Pennzoil/Quaker State filters are now produced by Purolator. So it's safe to say it's a better overall filter compared to the older findings which were made by FRAM. Though running FRAM(extraguard, High mileage) for 5,000KM OCI should be fine but I'd stay away from all FRAMs other than their Extended Guard/Synthetic Filter. You'd be surprised to find that this particular filter is actually quite well built, 2 layer filter media, Metal end caps, ADBV.
Don't forget, just because a filter is made with Metal end caps doesn't necessarily mean it's great. The number of pleats, flow, filter material, and the actual thickness of the filter housing plays a big role as well. | That's surprising to know that Pennzoil filters are Purolator. The article I read was from a few years ago, and mentioned the Pennzoil filters were garbage. The vehicle in question is my 1990 Corolla GT-S, and when I compared my old filter to OEM, the Pennzoil looked shorter but was the same diameter, had a weaker shell, and I believe had a crappy paper material.
Green OJ Special
07-28-2011, 07:54 PM
#192 | Unofficial Tin Foil Hat Specialist.
In recent years, I believe 1-2 years ago. Pennzoil/Quaker changed their Oil filters to Purolator. Most common filters on the market are made of a hybrid blend of Paper and some (minor) synthetic fibres. Some have more, some have less. Ofcourse this is all according to cost. But in the end, even a cheapy filter can filter out decent stuff as long as you do your oil changes regularly.
Anyway, in the end. Do your research properly, Just because a lot of filters are made by Purolator, Wix etc etc doesn't mean it's Super awesome. On a 3-5 dollar filter that's made by either of them, the internals may be of decent grade but the housing might be fairly thin or weak. Though, If I had to choose between a cheapy FRAM or a purolator, ofcourse I'd choose the latter.
Anyway, I thought about cutting up my filters and posting pictures but I need a decent size Pipe cutter or an oil filter cutter. Those things are quite expensive and no, a can opener won't do.
07-28-2011, 10:18 PM
#193 | I subscribe to the Revscene NWS thread(s)
Failed 11 Times in 6 Posts
Originally Posted by skyxx If I remember correctly, some Honda filters are made by FRAM, but the delearship does sell two types apparently. | This is true. The 15400-PLM-A01 is made by Filtech and the 15400-PLM-A02 is made by Honeywell (which is the same company that makes Fram).
07-29-2011, 03:35 AM
#194 | Rs has made me the woman i am today!
Failed 771 Times in 208 Posts
Since there are so many "good quality" oils out there, and everyone says dont use "crappy" oil lets list what kinds of oils are "crappy"
07-29-2011, 08:12 AM
#195 | Say NO to blade grinders!
Failed 67 Times in 49 Posts
OEM Toyota should be fine if you are doing regular oil changes. If you are going for extended intervals, then I would maybe look into something else. OEM Toyota is definitely better than your average FRAM though.
07-29-2011, 08:14 AM
#196 | Even when im right, revscene.net is still right!
Originally Posted by iamon a question for all of you, this is the first time i will be changing my own oil at home, and my driveway is slanted, do you think it would be dangerous if I jack my car up on the driveway and use jack stands or would I break any bylaws by doing my oil change on the street? | i don't think you will break any laws.. and is not safe at all.
07-29-2011, 09:22 AM
#197 | I subscribe to Revscene
Yikes. Don't be on the news. Jacking your car up while on a slanted road is asking for instadeath.
10-03-2011, 10:06 PM
#198 | RS.net, where our google ads make absolutely no sense!
Failed 51 Times in 8 Posts
where do you guys get your oil changed (besides DIY)? I don't want to go to the dealer anymore (toyota). The oil change itself is not expensive, around $40, but when they do the bigger service every other time, it's like $200- $250 and when I read the list of what they did, it's mostly check this, check that, not really fixing or replacing anything.... I wouldn't mind paying $200 if they actually replaced something but most of the time it's a thorough inspection... maybe a tire rotation but i can get that for free at Costco.
10-04-2011, 10:46 AM
#199 | nuggets mod
Failed 178 Times in 60 Posts
Originally Posted by matrixfwd where do you guys get your oil changed (besides DIY)? I don't want to go to the dealer anymore (toyota). The oil change itself is not expensive, around $40, but when they do the bigger service every other time, it's like $200- $250 and when I read the list of what they did, it's mostly check this, check that, not really fixing or replacing anything.... I wouldn't mind paying $200 if they actually replaced something but most of the time it's a thorough inspection... maybe a tire rotation but i can get that for free at Costco. | Why don't you tell them to just do the oil change?
10-04-2011, 11:49 AM
#200 | RS.net, where our google ads make absolutely no sense!
Failed 4 Times in 3 Posts
What's your guys opinion on high mileage vehicles (150KM+) running synthetic oil? I've heard it could eventually lead to oil leaks. What's your guys opinion on it? Posted via RS Mobile |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -8. The time now is 02:49 AM. |
