Maintenance, Engine & Driveline Tech This forum is brought to you by The Speed Syndicate (TSS) in Burnaby. Discussion of maintaining your engine, transmission, differentails, rear ends, and mods associated with "driveline" parts..  |  |
06-25-2012, 06:47 PM
#1 | | Proud to be called a RS Regular!
Failed 19 Times in 4 Posts
| HELP! 2007 Lincoln MKX AWD Transmission Problem
Hi,
I am in urgent need of help, as we have been driving the family car an '07 MKX AWD, and when we shift from Park to Drive, the shifts are very like rough sort of a clunking sound. But the problem only gets worse, when we drive and reach about 1500 RPM on first I believe (even after adding the proper transmission fluid) the car jerks as if it went over a pot hole or a ditch and there is this horrible thumping sound that comes out. So we decided to park it at our place and drove it below 1500 revs without it shifting (under 20 km/h, i believe), and it still had this knocking sound that came from the engine once in a while and the engine heated up quite quickly even though we didn't drive it that hard.
Do you guys think my tranny is going or what else can be the problem?
I'd take it to the dealer but its in richmond and we live in vancouver, so we have to get it towed. But it's so sad how we just bought this car only a year ago and it's already having problems, it really sucks.
Anyway, I look forward to your replies!
Thanks!
06-25-2012, 08:13 PM
#2 | | RS.net, helping ugly ppl have sex since 2001
Failed 11 Times in 7 Posts
are all 4 tires the same size, brand
Its Klobbering Time!
06-25-2012, 08:56 PM
#3 | | Proud to be called a RS Regular!
Originally Posted by Klobbersaurus are all 4 tires the same size, brand | Yep, all are same size and brand.. This problem just started happening recently.
06-25-2012, 10:43 PM
#4 | | "Entertainment" mod.
Failed 161 Times in 60 Posts
It does sound like a transmission issue to me (from what complaints you provided anyway), is warranty still available on the car?
Green OJ Special
06-26-2012, 12:05 AM
#5 | | My homepage has been set to RS
Failed 59 Times in 28 Posts
Sure it has proper level of fluid?
Warm and car is levelled and idling?
If it is, maybe a spring is broken.
And yeah, Sounds like a trans issue
06-26-2012, 01:12 AM
#6 | | Proud to be called a RS Regular!
Yeah we purchased an extended warranty with the car, but with a $300 deductible.
Fluid was low before, and apparently this was happening before too, but we filled it up with proper ATF fluid from dealer and yet this problem persists. The car is warm yes, but gets hot really fast as compared to before and like I said shifting from Park to Drive, etc. is noisy too. Do you guys think it's serious?
I thought MKXes and Ford Edges are relatively reliable cars, what do you guys think? Should we keep this car or will it give more problems in the future?
06-26-2012, 09:57 AM
#7 | | I contribute to threads in the offtopic forum
we are in richmond swing by and I'll take it for a spin
__________________ Rise Auto Salon
I can be reached VIA text @ 778-232-1465 Oil change special $70 5 liters synthetic oil including OEM filter Fender rolling from $45 per fender Car Audio:
General Maintenance |
06-26-2012, 10:12 AM
#8 | | Returner of Lost Phones and Turtles
Failed 217 Times in 69 Posts
Originally Posted by EUPHORiA1911 Yeah we purchased an extended warranty with the car, but with a $300 deductible.
I thought MKXes and Ford Edges are relatively reliable cars, what do you guys think? Should we keep this car or will it give more problems in the future? | Shifting clunk from park to drive is normal if you're on any slight incline when the car is parked. If you have warranty then it's all good see what the dealer says first
06-26-2012, 12:53 PM
#9 | | Proud to be called a RS Regular!
Yeah well the clunk wasn't that noticeable until now, it's gotten noticeably louder
Also, I can't drive the car after first gear it just doesn't go any faster I believe..
I'm gonna go to the dealer first, and then go to other mechanics because I can't really drive it at all, need to tow it |
06-26-2012, 09:05 PM
#10 | | Where's my RS Christmas Lobster?!
Failed 126 Times in 42 Posts
Originally Posted by EUPHORiA1911 Yeah well the clunk wasn't that noticeable until now, it's gotten noticeably louder
I'm gonna go to the dealer first, and then go to other mechanics because I can't really drive it at all, need to tow it  | why were you still trying to drive it? |
06-26-2012, 10:43 PM
#11 | | Proud to be called a RS Regular!
^Well, I was sorta in the middle of a busy road near my house when this started to happen, so decided to drive it really slowly and park it back at our place since it was so close anyhow.
06-27-2012, 09:34 AM
#12 | | 2x Variable Nockenwellen Steuerung
Failed 67 Times in 51 Posts
Modern transmission has built in ECU in the housing. It has probably gone into limp mode (that's why you can't drive at a higher speed). If you have a Ford specific scanner, you can scan the error code. You shouldn't have driven it to test it like that, chances are there is something wrong with the fluid flow in the transmission, testing it like that won't make it come back to life. $300 deductible on a $3k-4k part is not that bad. However deductible doesn't sound like a factory warranty.
I won't say it is the reliability factor of Ford unless you know what the previous owner (which I assumed you bought it used since you said you got it last year and it is an 07), did to the car.
Since it is AWD.. make sure when they tow it all, 4 wheels are not touching the ground. AND you read the manual to make sure all procedures were followed.
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -8. The time now is 07:04 AM. |
