Old 08-16-2013, 11:22 PM   #1
NEWBIE ACCOUNT!
Failed 4 Times in 1 Post
Car battery reads 0 volts, and will not charge. Did my battery die??
Yup the car wasn't driven for 1.8 months, i tried to start it up today but it didn't work.... So then i thought ok all i need to do is charge it up with the crappy moto master battery charger but it doesnt charge, it just flashes 8 8 8.... so i thought ok maybe i should check the voltage with my volt meter... and it reads 0, yes 0...
Is my battery garbage now??? the battery is only less than 1 year old.. what a piece of....
weed-man is offline   Reply With Quote
Old 08-16-2013, 11:33 PM   #2
snails's Avatar
Failed 253 Times in 80 Posts
well you let it die... if it was grounded then it would have been losing a charge the whole time it was hooked up...
so in short, yes it is dead. next time start the car once every 2 weeks at least, and disconnect the ground from the battery if you are going to let it sit.
Old 08-16-2013, 11:48 PM   #3
Iceman-19's Avatar
Failed 407 Times in 100 Posts
Yes essentially it is. Your battery is flat. A dead battery read 12.0 volts.
Iceman-19 is offline   Reply With Quote
Old 08-16-2013, 11:56 PM   #4
Head Moderator
Lomac's Avatar
Failed 98 Times in 51 Posts
Yup, that battery is toast.
You can try and rejuvenate it by hooking it up for a slow, deep charge, but even if it works it wont be as good as when new.
Old 08-16-2013, 11:57 PM   #5
NEWBIE ACCOUNT!
so i need to buy new battery??? does warrenty cover this??
Old 08-16-2013, 11:57 PM   #6
Iceman-19's Avatar
You can always try. Worst they will tell you is no.
Old 08-16-2013, 11:58 PM   #7
corollagtSr5's Avatar
Failed 294 Times in 64 Posts
If you have a receipt, you can try.
corollagtSr5 is offline   Reply With Quote
Old 08-17-2013, 12:08 AM   #8
NEWBIE ACCOUNT!
hmm yeah might as well, i have to recycle it anyways.. thanks all..
Old 08-17-2013, 12:33 AM   #9
Where'd you buy the battery from? And what car is this?
Old 08-17-2013, 11:00 AM   #10
Failed 68 Times in 25 Posts
My friend left his headlights on one night, and my meter tested it to be around 1.5v. We jumped it, and it charged back up just fine.
I've always thought anything below 10v is a dead battery, but turns out, it's not always the case.
Geoc is offline   Reply With Quote
Old 08-17-2013, 11:10 AM   #11
Waxin’ Punks
punkwax's Avatar
Failed 216 Times in 114 Posts
1.8 months hey...
punkwax is online now   Reply With Quote
Old 08-23-2013, 12:09 PM   #12
Rider
dink's Avatar
Failed 13 Times in 10 Posts
if the battery is below 11.6 volts, then it is drained and will not hold a charge.
Next time, disconnect the battery and hook it up to the charger.
Unless you're able to take the car out for a long drive once a week.
http://www.revscene.net/forums/dink-8-0-t263995.html
dink is offline   Reply With Quote
Old 08-28-2013, 07:40 AM   #13
Say NO to blade grinders!
Expresso's Avatar
Failed 67 Times in 49 Posts
I guess I'll hijack this thread since mystery is solved.
Even when I disconnect my ground, the battery will eventually die in a week or ten days. Is my battery garbage too? If I drive the car everyday, I don't notice anything. Usually I'm forced to leave it on a charger so this doesn't happen.
Old 08-28-2013, 11:06 AM   #14
koukimonst3r's Avatar
Failed 5 Times in 3 Posts
^ yup need new battery. Not holding charge
koukimonst3r is offline   Reply With Quote
Old 08-28-2013, 02:03 PM   #15
finbar's Avatar
Failed 268 Times in 45 Posts
Time for a new battery before it leaves you stranded.
finbar is offline   Reply With Quote
