Go Back   REVscene Automotive Forum > Technical Discussion > Manufacturer Tech Forums > Honda / Acura Tech Resources
THIS ADSPACE OPEN FOR ADVERTISEMENT
Old 11-01-2013, 03:58 PM   #1
Jaffray's Avatar
Failed 7 Times in 4 Posts
1997 Integra overheating @ idle problem, Help!
Hey guys,
So I've been driving down to clark and back home. And along the way home, noticed my integra was overheating at idle.
This happened before due to a ripped hose and bad clamp.
Problem has resurrected, I managed to get home so I can check out what was wrong.
After checking it out, turns out I can't find any faulty or ripped hoses. But noticed my coolant reservoir was half empty from full. Help?
Also noticed this happened after I parked my integra.
Jaffray is offline   Reply With Quote
Old 11-01-2013, 09:36 PM   #2
Have you checked the rad for cracks?
Old 11-01-2013, 10:35 PM   #3
Jaffray's Avatar
No I haven't but will keep that in mind for tomorrow morning. Thanks
Old 11-02-2013, 02:08 PM   #4
Puck Luck's Avatar
that looks like oil on the ground. by any chance, your car an automatic?
Don't open your hood to strangers........ N 'ouvrez pas votre capot à des inconnus
Puck Luck is offline   Reply With Quote
Old 11-07-2013, 03:01 AM   #5
ilovebacon's Avatar
Failed 1,107 Times in 281 Posts
this happened to me before. I had a crack so I had to get it fixed or else it would keep overheating. I was driving a rsx though. Another way of keeping it cool is by blasting your heat high. It will slowly come down as u watch the gauge. Hope this helps.
ilovebacon is offline   Reply With Quote
Old 11-07-2013, 11:55 AM   #6
Prolowtone's Avatar
Failed 13 Times in 7 Posts
check for leaks then test your thermostat to see if it is opening. if thats all good try a rad flush (flush ita few times).
if its still overheating after that you could have a bad head gasket allowing exhaust gasses to build up in your coolant...
Prolowtone is offline   Reply With Quote
Old 02-13-2014, 05:27 PM   #7
k20a's Avatar
Failed 3 Times in 2 Posts
How long ago did the broken/ripped hose happened? Did you properly bleed the cooling system after the repairs?
k20a is offline   Reply With Quote
Old 02-14-2014, 07:18 AM   #8
I told him no, what y'all do?
GLOW's Avatar
Failed 106 Times in 68 Posts
had 2 heating problems you described with my previous car and these were the causes.
Greenstoner
originalhypa
Old 02-24-2014, 03:10 PM   #9
I LIKE JDM!!
european's Avatar
Failed 13 Times in 3 Posts
I had a similar issue but with my 97 Honda Prelude, it would start to overheat at idle. After poking around I noticed that the radiator fan motor had died. I installed a new OEM fan motor and everything was back to normal. Perhaps you have something similar? I dunno, just a thought.
YouTube
Instagram
flickr
Twitter
Portfolio
Old 02-25-2014, 02:54 PM   #10
Witness protection
thumper's Avatar
Failed 111 Times in 57 Posts
the coolant overflow reservoir is not the best indicator of how much coolant there is in your engine, unlesss it's bone dry or it's overflowing with boiling coolant, of which neither is what you are experiencing.
when you blew your coolant hose, how was the engine refilled with coolant? was it properly bled of air?
with a the engine cold, did you check the coolant level from taking off the radiator cap and looking inside? how is the condition of the radiator cap itself?
how does your coolant look inside the radiator? ie. normal color, or is it like brown porridge? are there bubbles coming out while the engine is running?
have you had any issues with the thermostat? is the cooling fan coming on at engine temp?
i can't tell much from that picture why there is oil on the ground. have you looked for any obvious signs of oil leakage? what is your oil level like?
Old 02-25-2014, 02:59 PM   #11
snails's Avatar
Failed 253 Times in 80 Posts
if you cant see signs of a leak the first place i would look is at your thermostat, if you notice a difference in temperature in the hoses coming off your rad "top and bottom" then there is a good chance your thermostat is stuck closed
next would be rad fan, you said it was an idle thing so you might wanna check to see that your fan turned on
Old 02-25-2014, 09:01 PM   #12
welfare's Avatar
Failed 286 Times in 153 Posts
actually, there should be some difference in temp between the upper and lower rad hose. remember, the rad is supposed to lower the temp of the incoming coolant
Gold is the money of kings;
-Norm Franz
