Smatphones, Tablets, Pagers (lol), Accessories, Networks, Services, Tips & Tricks, Download ringtones, Screen savers.. | |
02-25-2014, 12:56 AM
#1 | I keep RS good
Failed 869 Times in 293 Posts
| Rogers LTE problem (or iphone 5s problem?)
I have a bell iphone 5s. got it unlocked, and im with rogers. everything works but if i enable LTE, it says "LTE" on the top left but data doesnt connect to anything. as if data was turned off.
wtf?
02-25-2014, 01:52 AM
#2 | not the mod you're looking for
Failed 83 Times in 32 Posts
A common problem with Rogers that I've experienced for years, but who knows, it might be your phone. Even when I'm on LTE and my phone tells me I have 3 bars, it struggles to load Google.
02-25-2014, 03:36 AM
#3 | I only answer to my username, my real name is Irrelevant!
maybe you have to manually enter rogers data address into the phone?
i remember needing to do that with my unlocked phone before because the phone wasn't reading/entering the info from the sim card correctly
02-25-2014, 06:33 AM
#4 | Media Officer / MOD
Failed 85 Times in 63 Posts
Originally Posted by StylinRed maybe you have to manually enter rogers data address into the phone?
i remember needing to do that with my unlocked phone before because the phone wasn't reading/entering the info from the sim card correctly | there's no such thing anymore
make sure you have the following:
your phone is a canadian phone with canadian lte bands
your plan is lte enabled
your sim is lte capable
02-25-2014, 07:07 AM
#5 | I answer every Emotion with an emoticon
If its data issues, could be related to APN settings
02-25-2014, 10:33 AM
#6 | I subscribe to Revscene
Failed 2 Times in 1 Post
lteinternet.apn Posted via RS Mobile |
#7 | reads most threads with his pants around his ankles, especially in the Forced Induction forum.
Failed 929 Times in 340 Posts
Originally Posted by FerrariEnzo If its data issues, could be related to APN settings | +1 have to do that to my unlock international version of Z1.
02-26-2014, 03:31 AM
#8 | I only answer to my username, my real name is Irrelevant!
your sim is lte capable | Quote:
Originally Posted by akira112 lteinternet.apn Posted via RS Mobile | yeah that's what i meant
02-26-2014, 08:34 AM
#9 | I contribute to threads in the offtopic forum
Failed 192 Times in 79 Posts
I don't think you can change APN settings on apple. With androids though, you almost always have to.
Reset your network settings on the phone. Does data work with LTE off? Posted via RS Mobile |
02-26-2014, 12:35 PM
#10 | Media Officer / MOD
APN settings is automatic read off the sim, go to Settings -> General -> reset -> reset network settings. Give that a shot, if that doesn't work head over to the Apple Store and see if they can give you a hand.
02-26-2014, 03:50 PM
#11 | I contribute to threads in the offtopic forum
One more thing..if reset network settings doesn't work, factory reset the phone and reactivate it with the Rogers Sim in the phone (could solve APN issue if you simply put the rogers Sim in the phone after it was unlocked. Posted via RS Mobile |
02-26-2014, 03:57 PM
#12 | RS Veteran
Failed 452 Times in 291 Posts
Spoke to Ulic earlier today. A new SIM solved the problem.
__________________ Quote:
Originally Posted by Badhobz I only get turned on by professional whores where whoring is their profession. Not whores who are professionals. yuck, that means I have to actually listen to the shit that comes out of their mouth. | |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -8. The time now is 12:05 AM. |
