Go Back   REVscene Automotive Forum > Technical Discussion > Manufacturer Tech Forums > Honda / Acura Tech Resources
THIS ADSPACE OPEN FOR ADVERTISEMENT
Old 07-24-2018, 01:29 PM   #1
I am Hook'd on RS
XSSIV's Avatar
Failed 25 Times in 3 Posts
EG6 Parts/Replacement: Oil Pan
Hello all,
I'm in the middle of fixing up my Civic and I need a new oil pan.
Wondering what the community considers a strong brand.
I'm working my way from the back to the front and I have very little knowledge on cars and aftermarket parts and what's good quality vs not - so hopefully you guys can help me along the way.
I haven't pulled out the current pan, so I'm not sure what's in there. Could be a modified stock pan - not sure.
Some details - I have a B18 84mm block with a B16 head/vtec w/ Garrett T3/T4 turbo and the car is lowered.
Thoughts here?
Help is much appreciated!
XSSIV is offline   Reply With Quote
Old 07-24-2018, 02:22 PM   #2
Failed 73 Times in 28 Posts
What’s wrong with the current pan?
cdizzle_996 is offline   Reply With Quote
Old 07-24-2018, 02:44 PM   #3
I am Hook'd on RS
XSSIV's Avatar
It's leaking oil out of the pan in several places. It looks like they may have modified the pan.
Also have a turbo oil leak may or may not have something to with the pan.
Also oil gauge isn't reading properly perhaps.
Old 07-25-2018, 10:44 PM   #4
Failed 1,518 Times in 655 Posts
moroso has always been a big brand in aftermarket oil pans.
Old 07-26-2018, 08:51 AM   #5
I am Hook'd on RS
XSSIV's Avatar
Glad to hear! It's pretty much the only one I could find online.
Looks like mopac in Langley is a dealer. $400 for the pan tho ouch! LOL...
Cheers!
Old 07-26-2018, 12:44 PM   #6
Can’t just replace the pan gasket for like $20 and 15min?
Ran factory pan on 5 turbo’d Honda’s
Old 07-26-2018, 01:03 PM   #7
I am Hook'd on RS
XSSIV's Avatar
I've taking it apart tomorrow morning. I'll post some photos of the progress and what's going on (haven't removed the pan yet). Could just be some lines are broken. Ultimately, I have an oil leak. Doesn't appear to be engine. Turbo and pan are affected though.
When I turn the car on, a bunch oil spews out the turbo and there's noticeable leaks in the pan area too.
I believe it's a stock pan I got right now.
Old 07-26-2018, 01:56 PM   #8
mb_
WUB WUB WUB WUB WUB
mb_'s Avatar
Failed 202 Times in 90 Posts
Most of the time when oil pans leak, it's the gasket/sealant and not the pan itself
FEEDBACK (9-0-0)
SPOTTED
fuck you hipster
then fuck you hipster akinari
Old 07-26-2018, 03:34 PM   #9
I am Hook'd on RS
XSSIV's Avatar
I hope it's this easy!
I'll post progress
Old 07-27-2018, 12:00 PM   #10
I am Hook'd on RS
XSSIV's Avatar
So... I embarrassed to say that oil leak was a...
*Drumroll*
Loose oil filter....
I cleaned everything underneath, inspected all spots... Touched the oil filter and it was loose. Was able to give it about 4 spins with my fingers loose.
So everything seems tip top.
Just need to fix the cable on driver's side e-brake and clean her up and she'll be ready for the Vancouver streets!
Need new battery and glue as well. The rubber around the windshield is coming off.
Thanks for all the suggestions!
Glad it was a series of false alarms.
Old 07-27-2018, 12:21 PM   #11
I have Civic batteries.
Use urethane for the trim but mask off the area first. That shit is a bitch to get off and can make a mess.
Old 07-27-2018, 12:46 PM   #12
I am Hook'd on RS
XSSIV's Avatar
What does this mean?
I have a optima high performance agm battery. Bought July 16 2017. I have receipt. Was going to see if I can exchange.
Should I be using a different battery?
Old 07-27-2018, 12:54 PM   #13
If they'll replace it, why not?
Wouldn't be my first choice, otherwise.
Old 07-27-2018, 12:57 PM   #14
I am Hook'd on RS
XSSIV's Avatar
What battery should I use? I feel like I've been having battery issues since I've owned this thing.
Old 07-27-2018, 01:03 PM   #15
Optima quality has gone downhill and is pretty hit or miss.
Depends what you're doing with the car, if weight matters.
Old 07-27-2018, 01:44 PM   #16
I am Hook'd on RS
XSSIV's Avatar
Weight may matter one day.. when I'm less people like Louis says... So I don't think weight is an issue at the moment.
Old 08-15-2018, 12:42 PM   #17
I am Hook'd on RS
XSSIV's Avatar
Hey guys - so car SEEMS to be running strong.
However, as soon as I turn key, my oil pressure gauge goes past 100.
I've got a part lined up for me at Lordco to replace. But I'm concerned it may not be the gauge. It's like 120bones for this thing.
This is I believe what's in the car and what I've got on hold at Lordco.
https://www.autometer.com/2-oil-pres...ltra-lite.html
Thoughts?
